Kevin,
I'm still not sure what you are experiencing. I know you needed to know what a specific fuse was for, why one would be missing, a code you have, and now the voltages are all over the place.
When you say the voltage is all over the place, is the battery light coming on? The voltages you indicated sound normal, but they should be jumping back and forth while the engine is running. With the engine off, 12.4 is perfect. Running, 14.1 is perfect. However, they should stay somewhat consistent. The 14.1 will lower as electrical components are turned on, but shouldn't drop too far.
If the voltages are jumping, the voltage regulator, which is integral to the alternator, maybe going bad.
Let me know what is actually happening so I can better help you. Please understand that other than telling you what a specific fuse was for and what a code indicates, I don't know what is happening.
Jul 6, 2021 at 10:04 PM
