Under hood light
2002 JEEP GRAND CHEROKEE
186,700 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
STEELERDYNASTY
  • 50 POSTS
How do i add it to a vehicle not previously equipped? I got one from salvage but cannot see how/where to connect the wiring. There is no wiring harness connector (like there was on the salvage yard vehicle) under the cowl.
Mar 28, 2018 at 7:29 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I can say it is fed from fuse #7 in the junction block, so if there is no wire present run one from that fuse. Then ground, g106.
Mar 29, 2018 at 6:06 AM
STEELERDYNASTY
  • 50 POSTS
Stupid i know, but which junction block is this? Where is it located? Will connecting it here activate the light only when the hood is opened?
Jun 6, 2019 at 9:33 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Usually the light has a switch built in which activates when the hood is opened enough.
the junction block is located behind left side of dash.
Jun 7, 2019 at 2:54 AM
