Ran perfectly before, I had to replace the distributor and valve cover gasket due to leaking. I ensured the engine was on TDC by inspecting the timing marks and camshaft while the cover was off. I replaced the distributor and set it to 800 RPM but the best timing I can get is ~15 degrees BTDC. I took the car for Smog and it passed with flying colors.
Now it has a very slow throttle response and will not shift until it gets to 40MPH. I confirmed no broken wires, vacuum hoses, etc., and have replaced the Throttle Position Sensor. The distributor can only go in one way, but the top appears to be pointing at #4 wire when in the correct position. I pulled a replacement from the junk yard and had no improvement.
Apr 30, 2022 at 1:12 PM
