I have a M5OD manual transmission. Unable to engage first and second gears. All others work fine. No unusual noise when incidence occurred. No grinding or chattering.
Incident occurred with 1/2 ton load. Shifted into third gear on a gentle incline. Coasted to a stop at a STOP sign, no first gear, i engaged the brakes, still no first or second gears.
Engaged 4WD Low Range, engaged third gear and drove in low range until was able to engage 2WD at speed to continue home.
Pulled shift lever assembly from transmission. Replaced nylon bushings and replaced. No significant wear in evidence.
May 13, 2016 at 7:51 AM
