Okay, so I bought a used U341E transmission to replace the one in my car listed above (GT).
I have noticed with the U341E that on newer cars the gear driven speedometer sensor was obsoleted and the bore hole capped over but otherwise 100% identical.
The problem I am having is the car wants to use the gear driven speedometer sensor so I put one in the hole after removing the cap and noticed that the gear inside the transmission that drives this sensor is obsoleted as well. Verified using a bore scope to confirm its 100% not there.
Is it possible to use the electronic VSS sensor? Reprogramming the ECU to get the VSS output speed from this sensor or what must I do? Install the drive gear in the transmission?
Nov 27, 2018 at 6:36 AM
