U2023 code?
2007 MAZDA CX-7
132,567 MILES
TIFFANY1990
Need to know what it means?
Nov 5, 2022 at 6:05 AM
U2023 Ford Code - Fault Received from External Node. The Diagnostic Trouble Code (DTC) will set when the Instrument Cluster (IC) Module fault received from an external node or Anti-Lock Brake System (ABS) Module. I would check all fuses and then clear the codes, if has comes back I would replace the ABS controller. Here is a guide that will help you with the fuses:
Is the ABS light on? does it light up when the key is on engine off? Please let me know.
Nov 5, 2022 at 10:31 AM
