Tire pressure light?
2007 TOYOTA SIENNA
234,356 MILES • V6 • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 754 POSTS
The vehicle tire pressure sensor were replaced and program but the tire pressure monitor light on the dash keep On, When the vehicle is scanned the is no fault code on the tire pressure monitor memory. The light is just on What could be the cause and way forward?
Mar 13, 2024 at 6:19 PM
How many sensors were replaced? Does the spare tire have a sensor on it as well? If so, is the tire pressure low on the spare?
Next, when the sensors are installed, the transmitter ID needs to be registered with the TPMS module. Was that done? How were the new sensors programmed?
Mar 13, 2024 at 7:53 PM
BLESSING EWOBOR
  • 754 POSTS
Four tires were programmed.
The extra tire didn't have TPMS sensor.
The sensors were programmed with scanner where the Sensor I D were registered on the module.
Mar 13, 2024 at 10:36 PM
Have you tried resetting the light? There is a reset button above the DLC. See pic below.
Let me know. If there are no codes, the light won't go off, the tire pressure is where it should be, and the reset doesn't fix the issue, recheck to see if there is a signal from each wheel. One of the sensors may not be working or when programming the new sensors, it may not have worked.
Mar 14, 2024 at 8:09 PM
BLESSING EWOBOR
  • 754 POSTS
Thank you.
Mar 14, 2024 at 10:12 PM
BLESSING EWOBOR
  • 754 POSTS
The tire pressure light is off now, and the tire pressure was low. The tire pressure on the scanner was different from the real pressure on the gauge. that was the problem.
Apr 19, 2024 at 3:02 AM
BLESSING EWOBOR
  • 754 POSTS
The tire pressure light if off now, and the tire pressure was low. the tire pressure on the scanner was different from the real pressure on the gauge. that was the problem
Apr 19, 2024 at 3:04 AM
Thanks for the update. I'm glad to know you found the issue, and it is resolved.
Take care and as always, feel free to come back anytime in the future.
Apr 19, 2024 at 8:21 PM
