Hi, I have this Japan only Mazda model and it's hard to information on this car online. I have two questions.
1) What spec Serpentine Belt (Accessory Belt) does this vehicle use? I can't find it in the owner's manual.
2) The vehicle was in an accident and entire tailgate had to be replaced. The new one has an electronic lock with a switch in the handle where has the old one had a cable based locking mechanism. It connected to be car just fine, however, it does not work unless power sent directly to the lock's actuator. After checking the cabin fuse box, there wasn't a fuse in the "P.LIFT GATE" slot and there aren't any wires connected at the back of the fuse box for the lift gate. Any help getting it to work would be most appreciated.
Thanks.☺
Thanks.☺
Oct 12, 2024 at 6:10 PM
