That changes things. The "no bus" message on the instrument panel indicates a communication problem between various electronic control modules (ECMs) in the vehicle. In modern cars, there are multiple ECUs (Electronic Control Units) responsible for different systems such as engine control, transmission control, anti-lock brakes, airbags, etc.
These ECUs communicate with each other through a network called the Controller Area Network (CAN) bus. The CAN bus allows these modules to share information and work together to operate various vehicle functions efficiently.
When the instrument panel displays "no bus," it suggests that there is a disruption or failure in the communication on the CAN bus. This can occur due to various reasons, such as:
A faulty or disconnected wire or connector in the CAN bus circuit.
A malfunctioning ECU that is causing a communication loop error, disrupting the data flow.
Electrical issues, such as a blown fuse, that are affecting the communication system.
A software glitch or a programming error in one of the control modules.
When the "no bus" message appears, usually people experience problems with starting, shifting gears, or other functions.
So what does that all mean? We need to scan the can-bus. As mentioned, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them. Here is a link that explains how it's done.
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Is this something you can do or have done? Also, since there is no RPM movement on the tach, and I assume there is no spark at the plugs, it could be something as simple as a crankshaft position sensor or as involved as a faulty PCM.
Do me a favor. Take a look through this link and let me know if anything mirrors what you've experienced.
Let me know about the scan. If we don't do it, it will become a guessing game, and that can get expensive.
Jul 29, 2023 at 8:34 PM
