Engine cranks but will not start
2008 NISSAN ROGUE
143,000 MILES • 4 CYL • 4WD • AUTOMATIC
LADARYLMCCOY
The car turns over but won't start. Battery seems good. No dim lights and dash lights up. Tried spraying starter fluid in intake with no luck.
Jan 29, 2021 at 3:15 AM
SEVAG P
  • 405 POSTS
hello,
Sounds like no spark. to narrow down our problem read the fault codes then send to us for proper diagnosis. many thigs can cause no start problem. crank sensor, ignition system, fuel system.
check our guide how to read fault codes.
Check our guide below how to fix not start problem.
https://youtu.be/dCjmRL3p4Cs
Also perform ignition spark test.
Let us know what happens with you.
thank you
Jan 29, 2021 at 5:23 AM
