Turning signal
1998 CHRYSLER CIRRUS
154,000 MILES • 0.5L • 6 CYL • 2WD • AUTOMATIC
RANDYMARI
Turning signal blinking fast. changed bulb one day prior for rear brake light and now neither work. But when I changed the brake light it still did not work. Could it be the relay? Help
Feb 4, 2017 at 10:20 AM
HMAC300
  • 48,601 POSTS
it may be the incorrect bulb or it is in wrong. also, does front signal work?
check to make sure socket Is in good and has a good ground.
Feb 4, 2017 at 10:33 AM
RANDYMARI
Yes front signal works. I will check bulbs again.
Feb 4, 2017 at 1:45 PM
HMAC300
  • 48,601 POSTS
check to see that there is a double filament in bulb. also, if a cheap bulb made in China will do that.
Feb 5, 2017 at 3:45 PM
