Turn signals will not work
1987 OLDSMOBILE CUTLASS
63,331 MILES • 2.8L • V6 • 2WD • AUTOMATIC
YEETICUS
Bulbs are not burnt, I have replaced the fuse and still nothing. Hazards and everything else work.
Oct 11, 2018 at 9:51 PM
Good morning.
The older cars have a separate flasher for the turn signals and hazards. I attached a picture of the location for you. Try replacing this flasher. You should be able to reach under the dash and remove it.
The turn flasher is located behind I/P, right of steering column.
Oct 12, 2018 at 3:20 AM
