Do they light up but not flash? or do they do nothing? Rear only or both front and rear? What happens when you turn on the hazard switch?
Fuse wise it is a 20 amp in the fuse panel in the end of the dash.
If they turn on but do not flash, and you do not hear any clicking, the turn/hazard module is mounted behind the dash to the right of the radio.
A rather common failure on these is the actual contacts in the hazard switch. Not a hard item to replace if it is the problem.
Jan 11, 2017 at 8:23 PM
