Turn signals and Hazards not working.
2003 CHRYSLER PT CRUISER
140,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
MARINA3141
The turn signals and hazards are not working on my car. The bulbs are working just find. I replaced the fuses, multi functional switch, relay, and still nothing. The headlights, fog lights, wipers, etc are still working. It's just the turn signals and hazards and inside on the panel show nothing either.
Jun 17, 2015 at 4:37 PM
HMAC300
  • 48,601 POSTS
you probably need anew combination flasher see pic.
Jun 18, 2015 at 6:36 AM
LESR1967
Replaced switch due to fog lights coming on while car off. Now no turn signals or four ways.
Mar 4, 2019 at 5:19 PM (Merged)
CADIEMAN
  • 3,544 POSTS
those are 2 different circuts.check the signal fuse.then check the flashers.i hope you installed the switch right because both of these are controlled by the signal switch.
check grounds on what? remote works locks locks works but with no turn signal bulds flashing and no horn sounnd and far as the remote start i think once i get the lights flashing when i lock or unlock the doors the remote start will work again oh i also checked all the fuses none are bad 3,10,13 fuses in the dash all good
CADIEMAN
  • 3,544 POSTS
its hard to follow your problem pl. write it over. ty
