Several months ago, I had new struts and shocks installed along with 4 new tires. I had the front end alignment done as well. When I got the car back, the steering wheel was cocked to the left (approximately. 10 O'clock). When I would put on the left turn signal, I would hear a clicking sound and the signal stayed on after I completed my left turn and I had to turn it off manually. This did not happen when I used the right signal, and the hazard lights worked fine. A few days ago, I was waiting to make a left turn and noticed that the left blinker wasn't flashing. I put it in the middle position and re-engaged it and nothing happened. If the steering wheel is in a certain position, everything works. Fuses are all fine but auto parts guy said I needed to replace the entire Directional Signal Arm Assembly, but the ones I see online don't look the same.
Dec 19, 2019 at 1:14 AM
