My info says it is a combination flasher and plugs into the multifunction switch. The multifunction switch is in the steering column connected to turn signal handle. The housing that is around upper part of steering column, remove lower housing, see if you can get at flasher. Your local auto store should be able to get that flasher for you, so you know what it looks like.
Our info says to take negative battery cable loose. It didn't say anything about an airbag, you always have to be careful about airbags.
May 29, 2015 at 9:03 AM
