No, that isn't true and that is why you are having trouble. It needs to be programmed with the proper RPO configurations. RPO (regular production options). Otherwise, there may be components or options in the vehicle that don't work properly.
As far as the anti theft, there are two ways to do it. One way is with a scan tool and takes 10 minutes and another is without the scan tool. It will take 30 minutes to complete the theft deterrent reprogramming. Here are the directions.
_________________________________________________________
30 Minute Learn Procedure
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON. The vehicle will not start.
3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the Passlock(TM) Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
6. Start the engine. The vehicle has now learned the Passlock(TM) Sensor Data Code and/or password.
__________________________________________________________
Let me know if that helps and gets you going.
Jun 26, 2020 at 8:57 PM
