Turn signals
2004 MAZDA 6
100,000 MILES
MC09
Both my left and right turn signals do not work. The fuse kept burning when i changed it, so i replaced the flasher relay because it burned when i installed it. It worked for a while, but the turn signals flashed fast and only the rear turn signals worked. After a minute the fuse burned out again.
May 16, 2016 at 2:05 PM
HMAC300
  • 48,601 POSTS
Sounds like you have a short in system maybe in the front. Check the wiring for a short to ground.
May 17, 2016 at 9:37 AM
