turn signal wiring diagrams?
1998 FORD RANGER
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
FRANKJAMES
I recently replaced the wiper motor plug and multi-function switch. Before, the problem was wipers inoperable. Now the wipers work along with everything else, but the turn signals do not work.
Nov 27, 2018 at 11:00 AM
It sounds like a fuse (#10, 21,13,11) is out, but to be sure lets use this guide and the wiring diagrams so you can see how the system works and the fuse locations as well.
Jun 2, 2021 at 1:51 PM
FRANKJAMES
Hello Ken! Thank you for your prompt reply and the helpful schematic images. I checked all of the fuzes and they were good. I dug back into my installation of the new multifunction switch and found that one of the plugs in the module plug cluster was improperly seated. Once I reseated the plugs the turn signals worked fine. Thanks for your assistance.
Good to hear, please use 2CarPros anytime we are here to help.
