I have no turn signals or emergency flashers?
1999 LINCOLN NAVIGATOR
200,000 MILES • 4WD • AUTOMATIC
STEVE GREENE
  • 5 POSTS
I have no turn signals or emergency flashers after I changed the battery terminals and master cylinder. I have checked the fuses and relay.
Oct 27, 2024 at 3:32 PM
Yep, it sounds like you have a turn/hazard flasher relay that has gone out due to a voltage surge which can happen when the battery is connected. Here is the location so you can swap it out to help fix the problem. Check out the images (below). Please let us know what happens.
Oct 28, 2024 at 11:08 AM
STEVE GREENE
  • 5 POSTS
I have replaced the relay and checked the fuses and still nothing.
Oct 28, 2024 at 11:22 AM
Okay, do you have power at the fuses # 23, #1 and #13 in the fuse panel inside the car, and fuse #6 in the fuse panel under the hood, this guide can help and I have included the blinker and hazard lights wiring diagram so you can see how the system works.
Turn the key on before testing for power on both sides of the fuses. Check out the images (below). Let us know how it goes.
Oct 29, 2024 at 10:33 AM
STEVE GREENE
  • 5 POSTS
I know #1 and #6 has power but I can't get a reading on #13 and #23 but I may not be doing it right because I'm using a multimeter instead of a test light and I was checking the amperage going through the fuse. Thanks for all your help.
Oct 29, 2024 at 1:32 PM
These fuses need to be hot at all times, no need to check amperage, just voltage. Please try again.
Oct 30, 2024 at 9:23 AM
STEVE GREENE
  • 5 POSTS
I have power on everything but #23.
Oct 30, 2024 at 10:56 AM
STEVE GREENE
  • 5 POSTS
I have power on #1, #6, and #13 all the time and #23 has power with switch on.
Oct 30, 2024 at 11:05 AM
Okay, that is good. Let's use a test light and check the ltblu and wht/red wires for power coming out of the flasher relay and if so, put the test light connected to power and with the relay removed check the blk wire for ground.
Oct 31, 2024 at 12:41 PM
