Hazards work both inside and outside bulbs flash. The turn signal will start, flash once or not at all and then stop. No turn signals! Located the junction box under dash near steering column but cannot figure out which relay goes to what? Have not taken out the arm to investigate the switch in the turn signal arm itself. I have tried moving the steering wheel up/down into different positions with no definitive change in turn signal operation. I am totally lost and clueless and yes fuses are good, changed them anyway to be sure.
Aug 13, 2022 at 7:21 AM
