Turn signal swtich worn
2004 MERCEDES BENZ C240
152,300 MILES • 2.3L • 6 CYL • 2WD • AUTOMATIC
WIN JAMES
  • 4 POSTS
I need to replace my turn switch signal indicator. I saw the video but I do not what tools are needed to remove the steering wheel, and the turn signal housing. The video was great except for kind of tools needed. By the way it is the four door sedan and it has a worn turn signal indicator. I saw 2CarPros excellent step-by-step video, but could not find a list of tools needed to do this job.
Thanks,
Win
Apr 20, 2017 at 10:21 AM
If I remember correctly, you will need a 10mm and a 4mm Allen wrench. It helps if you have all sizes becasue most of the time they come in the set. Use will also need two sizes of torx bits, and can get everything you need from Amazon
https://www.2carpros.com/articles/tools-and-supplies
Best, Ken
Apr 20, 2017 at 7:21 PM
WIN JAMES
  • 4 POSTS
Hi Ken, thanks for reply - Right now I have the 10mm and 4mm Allen wrench, I do have T25 Torx, do you recall what other size torx I need? They are $5 each at the store, or perhaps I need a set? Thanks for everything - you guys are great
Apr 21, 2017 at 7:44 AM
A set would be best becasue sometimes you will just need them. In a world of machines, we will need tools. cant go wrong.
Best, Ken
Apr 21, 2017 at 1:14 PM
