Sounds like the body module may be the problem then. If the grounds are good that is the only item that would cause an issue like that. You could try a hard reset but I'm doubtful it would do anything, for that you just disconnect the battery for about 5 minutes, then reconnect and see if they now work. Because they turn on but don't flash and you checked the grounds that only leaves the BCM as a failure because it is the only item they have in common. Unless it has non-stock lights that are wrong internally. Replacing the BCM physically is easy, but you need a dealer level scan tool and a connection to the GM software to program the replacement. They are not plug and play.
Body Control Module Programming and Setup
A new body control module (BCM) must be programmed with the latest operating software and vehicle calibrations. Ensure that the following conditions exist in order to prepare for BCM programming:
The battery is fully charged.
The ignition switch is in the ON position.
The data link connector (DLC) is accessible.
All modules and devices are connected.
Important- The vehicle will not start, and many other functions may not operate properly if a replacement BCM is not properly set up. The following procedures must be completed.
1. Programming the BCM-From the Main Menu, select Service Programming System, then follow the instructions on the screen. Refer to Service Programming System (SPS) for more information.
2. BPP Sensor calibration-Refer to Brake Pedal Position Sensor Calibration
3. Learning the restraints ID-Navigate on the Tech 2 to Vehicle Control Systems > Module Setup > Body Control Module > Setup SDM Primary Key in BCM, then follow the instructions on the screen.
After any programming or setup, perform the following to avoid future misdiagnosis:
1. Turn the ignition OFF for 10 seconds.
2. Connect the scan tool to the data link connector.
3. Turn the ignition ON, with the engine OFF.
4. Use the scan tool in order to retrieve history DTCs from all modules.
5. Clear all history DTCs.
Jun 28, 2025 at 6:27 PM
