Okay, let me preface this. I did the following:
I was working on my headlight from an earlier issue, and traced the problem to a lack of power going to one of the wires. Someone in a previous time, had added a junction wire from the front fuse box, into the main light cone for the headlight.
This proved to be a problem when installing LED lighting, plus the wires to the main plug were disintegrating. I replaced both sides with an OEM plug, and a bunch of 22AWG connectors.
I had to trouble shoot which wire was bad, and after basically screwing it up 3 times, and finding out the Red/Black wire was not a ground, I goofed when I touched the extra power line, to the Blue/White wire, that normally attaches to the signal light/parking light on the passenger side.
I heard an audible "click" from the area around the battery. Now, that the headlight is fixed, both high/low work. I have no turn signal on the passenger side only.
When I turn the signal on, I can hear clicking from the relay can under the dash, but also a clicking under the battery somewhere. The driver's side works, the passenger side is messed up.
So what did I blow up? And what do I need to do to fix this? By the way the traction control light, also flashes when I use the passenger side turn signal, and the parking light glows barely. I checked both the front and rear bulb and they check out okay.
Dec 2, 2020 at 8:40 AM
(Merged)
