The right rear turn signal was not operating. I am getting a "hyper-flash" indication when I use the right turn signal. I switched bulbs with the left side with the same result. In other words, the bulb is not the problem. I replaced the flasher with the correct Toyota part (81980-53020) which is the correct replacement for the original flasher (81980-50020). Same result. The right rear turn signal does not work, which indicates to me that there is no power to the right rear bulb socket. The front right turn signal works fine. What do I do now?
Sep 16, 2018 at 12:26 PM
