How to replace the turn signal lever?
1988 CHEVROLET CAVALIER
140,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
WAGONBRO33
  • 24 POSTS
Hey, I was just wondering if anyone knows how to replace the turn signal lever on the car listed above?
Oct 21, 2024 at 9:34 AM
Sure, here are the instructions on how to replace the turn signal switch lever. I would use a string to attach to the wiring so you can pull the new wiring through using the string you attached to the old wiring before you pull the old wiring through the steering column. Check out the images (below). Let us know if you need anything else.
Oct 21, 2024 at 4:36 PM
WAGONBRO33
  • 24 POSTS
Thank you so much. I’ll let you know if this works.
Oct 21, 2024 at 5:05 PM
Our pleasure, let us know how it goes or if you need anymore help.
Oct 22, 2024 at 10:22 AM
