turn signal/hazard flasher not working
2007 CHEVROLET AVEO
170,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
JOHN EDWARD
  • 15 POSTS
the turn signals and hazard lights do not work at all inside or outside. the switch and the fuses have been changed still nothing. could the flasher be bad it is only $15.00. Where is it located? The turn signals worked intermittently inside and out then just stopped working at all.
Mar 20, 2022 at 3:26 PM
BORIS K
  • 836 POSTS
On your vehicle the flasher unit is located in the left instrument panel fuse block.
See image below, item 2.
Please let us know how you get along.
Cheers, Boris
Mar 21, 2022 at 4:25 AM
JOHN EDWARD
  • 15 POSTS
Hi Boris, thanks for your reply. This is my daughter's car, it is a sedan, if that makes a fuse block on her car does not look like this at all. The relays on her car are under the hood. i will double check this evening and let you know what i find. i can take a picture of it if that helps.
thanks, John
Mar 21, 2022 at 5:18 AM
JOHN EDWARD
  • 15 POSTS
Hi Boris, i found the flasher relay and replaced it. It fixed the problem. thanks for your help. John
Mar 21, 2022 at 4:15 PM
