There is only one fuse which powers the entire system, hazard, left and right turn interior lights and marker lights as well as low beam headlights are all through that module. For it to be that fuse all of those lights would not be working, not just the left side turn signals. Your car is like most modern vehicles, they did away with the simple systems and went to control modules for everything, for instance the turn signal and hazard "flashers" no longer exist in your car, they are part of this same control module. When you said that it was both the front and rear as well as the dash lights that were out that confirmed it was the control module as they are all fed from the module but in two different control areas. The only way to repair it is to replace that module.
One of the things I really dislike about all of the modern vehicles. My wife drives one where they put a majority of the electronics like turn signals, high and low beam headlights, brake relay, fuel pump relay, and most of the rest as a self contained smart fuse box, they each have fuses, but I've only seen a few of those blow, instead the 5-cent fuse stays okay and wipes out part of the $800.00 fuse box instead.
Mar 20, 2022 at 4:59 PM
