Turn signal blinking rapidly
2000 BUICK REGAL
120,000 MILES • TURBO • AUTOMATIC
DROGAN1088
One of my turn signals is blinking rapidly. I have changed the bulb twice, but it continues to do it. To my knowledge, there is no relay for my car. It seems to do it consistently when my headlights are on, but it does happen when they are off. There are times when I would use the signal and it would blink rapidly, but suddenly start working properly.
May 3, 2016 at 9:04 PM
CARADIODOC
  • 34,306 POSTS
When the symptoms are different depending on whether the head lights are on or off, it is almost always a bad ground issue. Follow the wires from the socket to see if the one bolted to the body is cut.
May 3, 2016 at 9:19 PM
DROGAN1088
Would you happen to know where it would be grounded? I can see about 10 inches of wires before I lose track of them.
May 6, 2016 at 12:41 PM
These system ground are almost always by the incoming wiring harness near the main body mounts follow the harness until you see a black wire break out of the loom. Also, check the ground at the socket this is were the circuit usually goes bad.
here is a guide, to test it.
https://www.2carpros.com/articles/no-tail-lights-exterior-running-lights-tail-lights-out
Let me know how it goes
Best, Ken
May 8, 2016 at 11:00 AM
