Turn signal assembly
1991 PONTIAC SUNBIRD
200,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
GELVINN
For some reason, my turn signals will not work. I have checked the hazard lights and they work. I have replaced the turn signal switch inside the steering column, replaced the turn signal/hazard flasher (looks like it is only one unit combined), and replaced the fuse inside the fuse box. I inspected all turn signal/hazard light bulbs and all are good. I do have a new 30 amp circuit breaker installed also in the fuse box. and yet the turn signals still are not working. Any ideas?
Jul 25, 2017 at 9:19 AM
HMAC300
  • 48,601 POSTS
there is a turn signal relay on right side of steering column support for just turn signals. fuse 6 is for turn signals. See pictures for turn signal relay etc.
Jul 25, 2017 at 12:16 PM
GELVINN
Is the relay on the same piece as the break light, which is attached to the break pad stem? or is it behind the dash?
Jul 25, 2017 at 12:26 PM
HMAC300
  • 48,601 POSTS
it's under the dash on the steering column support which is a steel plate holding column in
Jul 25, 2017 at 4:23 PM
