First, make sure there is power to the fuses. Also, did you check or replace the signal / flasher relay?
I attached a couple pics below. The first shows the relay I am referring to. Pic 2 shows fuses you need to confirm are good and are getting power.
Next, I need to know if you checked or replaced the hazard switch. Power to the signals and the hazard lights go through that.
____________________
Start with this and let me know the results. Here are a few links you may find helpful:
https://www.2carpros.com/articles/how-a-car-fuse-works
__________________________
Pics 3 and 4 are the entire wiring schematic for these components. I had to overlap them to make them readable. I did overlap them so you can easily follow them.
Jan 31, 2020 at 6:48 PM
