When you pulled the fuses mentioned above, is there one that turned them off? If so, which one lets the signal dim and headlamp off?
The blue/white is for the signal and tan/white is the low beam. See pics below
I need you now to remove fuse 8 in the fuse box in-vehicle, left side. See pic 3. Does that turn them off?
If it doesn't, my theory is the fuse box (under the hood) may have failed. It contains PCB relays that power the lights/signals. PCB stands for printed circuit board and isn't repairable. However, before I jump to that, let me know about the fuse. If the lights still don't turn off, pull the HDLP low relay in the under-hood box and see if that does it. The only thing is I feel that it will shut other things off as well. See pic 4
If this doesn't lead us in the right direction, we will need to first disconnect the body control module and inspect pins in the connector to see if something is damaged causing the problem. If there isn't, then we need to start tracing wires to locate where the problem is located.
Wiring issues can be a nightmare, so hang in there. The idea that you disconnected the switch and the light stayed on tells me the problem is somewhere between the body control module, fuse box, or the wiring between them. If everything checks good, then it will likely be the fuse box that has shorted.
Take care and let me know.
Mar 5, 2022 at 7:30 PM
