The turn signal lights and the hazard light don't work. I have change the multi switch and change fuse, but it still nothing.
May 26, 2021 at 2:47 PM
CERTIFIED EXPERT
We need to check for power at the fuses to make sure they are good (the fuses are in the diagrams below). here is a guide to help you and the fuse location as well. Also I have included the turn signal wiring diagrams so you can see how the system works.
May 28, 2021 at 10:07 AM
RICHARD NEGRON BURGOS
MEMBER
I did check for power and it does have power going to the fuse.
May 28, 2021 at 10:16 AM
CERTIFIED EXPERT
Okay, let's check the TNS relay which in under the hood inside the fuse panel. here is a guide you help you test it. You you are in question try replacing it.
