The driver side turn signals and brake lights don't work but the passenger side does. Changed the bulbs and installed a new turn signal switch
Jan 23, 2016 at 7:09 PM
HMAC300
CERTIFIED EXPERT
check the yellow wire to see if any power is coming through it from t/s switch if not it may be a bad flasher which is hazard switch. alos check ground at taillight and parking light in front.
