Hi Strutter,
When you say nothing happens, I assume the engine does not turn over. Do the lights in the dash come on?
Do you hear the starter click?
When the humidity is high, it can affect electrical connectors and if they are not good clean tight connections then this humidity can cause them to malfunction.
Depending on if the dash lights come on or not, I am thinking you have an issue with your transmission range sensor circuit. This is basically the sensor that tells the PCM that you are in park or neutral and it is ok to start the vehicle. Next time this happens, turn the key on and shift the vehicle to neutral and then try to start the vehicle and see if it starts in neutral. If it does then this is your issue.
Let me know about the dash light when you turn the key on because if they don't come on then this is probably not your issue.
Thanks
Jun 10, 2019 at 3:54 PM
