Turn key no sound
2006 MITSUBISHI OUTLANDER
146,165 MILES • 2.4L • 4 CYL • AWD • AUTOMATIC
JEFFREY ALAN MARINELL
I try to start my car but nothing happens no sound no clicking no nothing!
I think it is the neutral lockout switch! I want to find out where it is located on my car so I can clean it.
When I shake the gear lever it will sometimes start but not always.
Do I have to replace the lock out switch or can I just clean it?
Jeffrey Marinell
Apr 2, 2017 at 12:14 PM
CARADIODOC
  • 34,306 POSTS
This is a transmission range switch, and is most likely a sealed assembly. Some cars use more troublesome transmission range sensors. I have heard of people cleaning those on Jeeps, but those too can be sealed assemblies. The better solution is to replace a defective unit.
Given your observation that moving the shifter can affect the symptom, do not overlook a loose shifter cable adjusting nut at the transmission end of the cable.
Apr 2, 2017 at 7:28 PM
There is no lock out switch. It sounds more like you have a bad connection at the battery and when you move the gear shifter it gives a small vibration that helps the connection. When you say it makes no noise you mean no lights on no nothing?
Best, Ken
Apr 3, 2017 at 7:53 PM
Ken, all the lights come on the warning bells the radio, and head lights. But when I turn the key there is no sound of cranking of the starter!
Jeffrey
PS, when I shake the gear shifter it will start, but I have to do it two or three times sometimes more sometimes less.
Apr 4, 2017 at 7:56 AM
Yep, a classic starter motor going out or the neutral safety switch shorting. Here are two guides to help you check out the problem and get it fixed.
and
https://www.2carpros.com/articles/how-a-neutral-safety-switch-works
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Apr 4, 2017 at 11:02 AM
