Tune up oil change
2001 NISSAN ALTIMA
325,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TRICKED
Hi, I recently had my car in for service. It went in for a surging problem in drive at a stop and an oil change. When I got it back I was told the cars cradle was rotten badly. However, the garage went ahead and did a tune up not asked for nor needed. When I asked why, I was told as a process of elimination for the surging. What I do not understand is do you not drain the oil before doing a tune up so therefor they would have known the cradle was rotted before doing it and notified me instead of costing me for more on a car I was being told was finished. not worth putting more money into? If you could also give me an idea of what might be causing the surging. It is still doing it and I found out the information I was given about the cradle was false. It only had a very small hole in it. The mechanic wanted my Nissan for his kid. Unfortunately, I only found out after I purchased a new car. Now I am stuck with both. Any information you could provide would be helpful. I tried to upload an image of the cradle but not sure it worked. It appears my image is not allowed. What type of file do I need to use to upload a picture to you?
Thank you.
Apr 20, 2018 at 1:06 PM
Good morning.
First, a shop cannot do any repair without your authorization. if you did not authorize the repair it should never have been done and you should not be responsible for the cost.
the oil change can be done at anytime whether the beginning or the end. there is no set protocol.
The surging can come from many areas. it could be EGR, low fuel pressure or catalytic converter. it could also be transmission related.
This is why you pay for a diagnostic. they tell you the issue without guessing.
Apr 21, 2018 at 4:38 AM
