Hi Darren,
I am a little lost because I am not looking at the same wiring diagram you are. However, here is what I understand. You tested your wiring going to your cluster and found the wire for your reverse lights? You said "rear light cluster" but I am not sure what this means.
Then you said you found the wire that lights the meter but when you select reverse the image does not come on. Are you getting your meter to light when you are in reverse? Meaning, it only lights the meter when you shift to reverse?
Either way, what I would suggest, is getting your reverse information from the reverse light circuit. This means when you shift to reverse the lights that come on in the rear of the vehicle, just tap into those. Those are 12 volt feed wires and most back up cameras require a 12 v feed.
Hopefully this helps. If not, can you attach your wiring diagram that you are looking at and the instructions for the camera? I can review those so we are on the same page and then we can get this figured out. Thanks
Kenny
Apr 16, 2019 at 7:03 PM
