I suspect problem is some type of sensor. Trunk will not open either from using key or release latch inside. Just recently the back door passenger on drivers side will not lock with key, but manually I can push lock and close door to lock. Now the gas door release latch is only working off and on to open gas door.. The instrument control panel goes completely dark at times, an older problem
Sep 2, 2013 at 7:42 PM
