Trunk lid opens simultaneously?
2010 BUICK LA CROSSE
105,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
PETER THE EATER
  • 24 POSTS
Upon cranking the vehicle the trunk lid opens simultaneously. I open the trunk to investigate and found the emergency release handle dangling . Could that be the issue??
Sep 23, 2025 at 6:31 AM
Hi:
I would like to say it is related to the dangling release cable, but that is a mechanical device. Turning the key on shouldn't actuate it.
However, since this is a new finding, I would recommend checking into it. I say that because if the cable or release is damaged, the deck lid may not be properly latched. I tried to find the specifics on the emergency release without success, but I would like to help.
If it is possible, close the trunk and confirm it is fully seated and not able to be opened by hand. If it is, please send pictures of the handle so we can see exactly what you are referring to. We should be able to further direct you at that point.
Take care and let us know what you find.
Sep 24, 2025 at 7:51 PM
