Truck will not move
2004 FORD F-250
100,000 MILES • 4.6L • 4WD • MANUAL
RPMs high gears shift good truck wont move.
Feb 5, 2021 at 10:53 AM
I am not sure I understand the issue. I understand that the truck won't move but does it just rev like it is in neutral? What do you mean by high gears shift good? If the truck doesn't move, how do you know the high gears are fine? Does it go into first with no grinding?
Do you just mean that you can't get it moving from a stop and if you get it rolling the vehicle will drive?
More then likely this is just a clutch issue and it needs to be replaced but normally this is due to not going into gear so I am just a little confused on what it is doing.
Here are some guides that run through all this info. Take a look at this and let us know what we are missing. Thanks
https://www.2carpros.com/articles/inner-workings-of-a-car-clutch
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
https://www.2carpros.com/articles/clutch-symptoms
https://www.2carpros.com/articles/how-to-replace-a-clutch
Feb 6, 2021 at 3:46 PM
