Truck won't run
2009 TOYOTA TUNDRA
180,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
CHRIS.EARTH87
  • 8 POSTS
I was on my way to work yesterday and I lost engine power my truck started clanking and I pulled over and looked under my hood and open my oil cap and it was tan and color and kind of chunky I could not get past the speed limit of 45 and it started spitting and sputtering every time I let off the gas it would die and I'd have to read crank it while pressing the gas and now that I've got it back home I can't get it to crank up it will turn over but will not crank up it kind of was acting like it was running out of gas or it has really bad gas but my gas gauge read fine
Dec 19, 2015 at 10:34 AM
WRENCHTECH
  • 20,761 POSTS
Have you checked the level and condition of the oil?
Dec 19, 2015 at 2:05 PM
CHRIS.EARTH87
  • 8 POSTS
Yes it was very low and tan and thick
Dec 19, 2015 at 3:11 PM
CHRIS.EARTH87
  • 8 POSTS
I added 4 quarts and I've been trying to crank it I've had no luck but it does seem to be trying
Dec 19, 2015 at 3:12 PM
WRENCHTECH
  • 20,761 POSTS
I think that engine is pretty much junk now. The milky look is likely from coolant that got into the oil, The combination of that and having virtually no oil at all would have destroyed all the bearings and other internal components.
Dec 19, 2015 at 3:18 PM
CHRIS.EARTH87
  • 8 POSTS
It acts like it won't get any gas and when I was driving it was spitting and sputering I had someone tell me it could be the fuel lines or the filter
Dec 19, 2015 at 3:47 PM
WRENCHTECH
  • 20,761 POSTS
That doesn't change the fact that it was driven 4 quarts low on oil and what little oil it had was mixed with coolant. That does major damage to the inside of the engine. You also haven't determined how the coolant got in there. That in itself could be terminal for that engine.
Dec 19, 2015 at 3:55 PM
CHRIS.EARTH87
  • 8 POSTS
Is there anything I can do and do you know what it would cost for a engine and have it put in
Dec 19, 2015 at 3:57 PM
WRENCHTECH
  • 20,761 POSTS
The only thing you can do is have it looked at by a professional and get and accurate diagnosis. As far as the cost, that totally depends on what route you take as far as rebuilding that engine, replacing it with a used engine or replacing it with a factory remanufactured long block. I'd say anywhere from $2,000 to $6,000
Dec 19, 2015 at 4:02 PM
CHRIS.EARTH87
  • 8 POSTS
What's the cheepest fix I'm very limited on cash and about to lose my job cause I have no ride to or from wrk but I'll have plenty of time and only about 600 to put in to it if I can I'll wrk to fix it with every thing I got
Dec 19, 2015 at 4:05 PM
WRENCHTECH
  • 20,761 POSTS
$600 won't even buy the parts, new or used.
Dec 19, 2015 at 4:07 PM
CHRIS.EARTH87
  • 8 POSTS
Well thanks for your help I wish it could have been a easy fix but Im never that lucky merry Christmas thanks again
Dec 19, 2015 at 4:11 PM
CHRIS.EARTH87
  • 8 POSTS
Oh can you give me a good guess on what I need for just the parts
Dec 19, 2015 at 4:12 PM
