truck will not move in 2 wheel drive, however when in 4-hi or 4-low it will move
1997 CHEVROLET SILVERADO
200,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
MRTUCKER
when i was on my way home coming up to a stop sign i herd a loud bang. when i tried to leave the stop sign it would not move while in 2 wheel hi, when i put it in 4-hi or 4-low it would go, but had a grinding sound and was leaking oil from the transfer case. sounds like the transfer case shot, is that the problem
Feb 11, 2014 at 4:11 PM
CARADIODOC
  • 34,306 POSTS
Someone is going to have to crawl under there to look at what is leaking. It is more likely a universal joint broke and the slip shaft fell out of the transfer case but you would see it hanging down. Has the truck been raised? If so, that changes the geometry of the drive line and puts added stress on the transfer case. The increased vibration can crack the transfer case housing.
Jan 2, 2020 at 9:02 PM
