Truck stuck in four wheel drive
1999 FORD EXPEDITION
240,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JAYAR BELISLE
  • 6 POSTS
When in drive/reverse out of a parking spot or make a turn truck makes a humming, clunking, and slows down or stops and have to give it more gas to move. When i drive straight all it does is hum. When i turn the electronic 4x4 knob the 4x4 light turns on and i hear relay clicking.
Apr 6, 2019 at 12:34 PM
It sounds like the encoder motor is seized up not tracking correctly. Here is a diagrams so you can remove the motor to see if it is working correctly. Please check it out and get back to me.
Apr 8, 2019 at 1:13 PM
JAYAR BELISLE
  • 6 POSTS
I removed the shift motor and the transfer case was already on 2 hi and the video is the shift motor switching AWD to 4 HI to 4 LO back to 4 HI to AWD.
Apr 9, 2019 at 3:56 AM
Thanks for the video, yes that seems to be working fine, can you tell where the noise is coming from?
Apr 9, 2019 at 11:39 AM
JAYAR BELISLE
  • 6 POSTS
The noise is coming from the front of the truck.
Apr 11, 2019 at 6:12 PM
Can you go for a ride and take a video so I can see what is going on?
Apr 12, 2019 at 10:10 AM
