Truck stalled after hitting a bump, will not start?
2013 RAM 1500
117,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BOSSMAN19
  • 21 POSTS
I was driving down the road, and I hit a bump. After I hit the bump, my truck immediately stalled out. Once I stopped, I tried to restart. It would crank but not fire. I have tested connections to he battery and all i could see under the hood and all seemed to be fine. Could it possibly be the fuel relay going bad?
Jan 30, 2024 at 2:47 PM
In most cases, a crank with no start is either the result of an ignition issue or fuel. We need to determine which is causing the problem.
Here is what I need you to do. See if the engine starts if you use starting fluid. If it does and then stalls, we will know it's fuel-related. If there is no change, then I need you to check for spark at the spark plugs.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
As far as a fuel pump relay, pay attention to see if you can hear the pump prime for a second when the key is first turned to the on position. There is also an automatic shutdown relay (ASD) relay that may be an issue. Either way, both will prevent the pump from running.
Try this and let me know what you find.
Jan 30, 2024 at 8:30 PM
BOSSMAN19
  • 21 POSTS
Awesome, thank you. I just dropped my wife off at work and now heading to get the starter fluid. I will also check for the fuel pump (something I completely forgot to do). I will let you know what I find out.
Jan 31, 2024 at 7:01 AM
BOSSMAN19
  • 21 POSTS
Alright so, just got back home. I sprayed the starter fluid and she acted like she wanted to start but couldn't roll over. Also, I did not hear the fuel pump. I also switched the ASD relay with another relay to test that out and nothing. The check engine light has not come on at all, but I did do a code check " just to see if anything popped up" to cover all basis. No codes.
Jan 31, 2024 at 7:47 AM
BOSSMAN19
  • 21 POSTS
I did test for spark as well and there is spark.
Jan 31, 2024 at 9:29 AM
If the ASD checks good, we need to check a couple of fuses and the pump relay.
If you look below, I attached a pic from the schematic. Check fuses 70 and 78 in the underhood fuse box. If they are good, remove the relay and locate connector pins 85 and 30 for the relay. Connector 85 should have power when the run start relay is closed. Check if that is the case.
Pin 30 should have B+ at all times. Confirm that as well. If they both get power, then I need you to jump connector pins 30 and 87 of the fuel pump relay to see if the pump turns on. If it does, then we likely lost ground at connector 86 which is provided via the PCM. If it doesn't turn on, we need to check if there is power at the pump when these are jumped.
Here is a link you may find helpful when testing the relay and its circuit:
See pic below.
Jan 31, 2024 at 7:31 PM
BOSSMAN19
  • 21 POSTS
Good morning. I will check these once I get out of work and let you know what I find out.
Best Regards,
Ben
Feb 1, 2024 at 3:53 AM
BOSSMAN19
  • 21 POSTS
Okay, so, fuses 70 and 78 are both good. Now the Fuel pump relay on Rams is located inside the TIPM and is soldered to the circuit board. Is there a way to test that without taking the TIPM apart?
Feb 1, 2024 at 10:46 AM
The only way is to check for power and ground at the wiring. Is that something you are comfortable performing? Let me know.
Feb 1, 2024 at 6:20 PM
BOSSMAN19
  • 21 POSTS
Hello, yeah, I would feel comfortable with that.
Feb 1, 2024 at 6:25 PM
You know what, let's try this in a different way that will be easier. Fuse 70 shouldn't have any power when the key is off. When you first turn the key on, it should have power. Check that. Do this with a helper so you can tell if power is available as soon as the key is turned on.
If it is, then I need you to locate the C3 connector at the power distribution center, locate pin 25 (brown wire), and check for continuity to ground when the key is turned on. A ground path should be provided to actuate the primary side of the relay and engage the secondary.
Let me know what you find.
See pics below.
Feb 1, 2024 at 7:08 PM
BOSSMAN19
  • 21 POSTS
Will do. I will check on this when I get home from work if my wife is home. If she's not I may have to do it tomorrow so bear with me if it takes me a minute to reply back to you.
Ben
Feb 2, 2024 at 4:23 AM
BOSSMAN19
  • 21 POSTS
Good evening. I checked fuse 70 and it's not getting any power at all. All other fuses are getting power.
Feb 2, 2024 at 2:43 PM
Fuse 70 is what sends power to the fuel pump once the relay is completed. So, either we have a faulty printed circuit board, the PCM isn't providing a ground path, or there is an open in the PCM not letting power reach the pump relay.
I don't want to say it, but I suspect the PCB is faulty. The bump may have caused a solder joint to crack.
Let me know if you are comfortable checking pin 25 on the C3 connector for continuity to ground. If you have a test lamp, connect the alligator clip side to the battery positive. The tester side goes to pin 25 on the PCM side. Have a helper turn the key to the run and then start positions to see if the test light turns on.
Feb 2, 2024 at 9:42 PM
BOSSMAN19
  • 21 POSTS
Hello. Okay, will do! I will let you know what I find.
Feb 3, 2024 at 5:52 AM
BOSSMAN19
  • 21 POSTS
Good afternoon!
I located C3 and pin 25 and nothing once the truck was turned to the run or start position.
Feb 3, 2024 at 12:17 PM
That would indicate the PCM isn't providing a ground path. On the other hand, you also indicated there is no power to fuse 70 when the key is turned on. Based on that, we have two different problems. Are you certain there is no power to fuse 70? And on the PCM itself, pin 25 doesn't provide a ground path?
I want to say the PCB/TIPM is faulty based on no power. The ground is something different. I wouldn't think both would fail at the same time.
Feb 3, 2024 at 3:49 PM
BOSSMAN19
  • 21 POSTS
I'm wondering if the connection on pin 25 could be corroded? I have a digital tester and the I would either get nothing or a very very faint green rather than the bright green or red with a power reading. Fuse 70 doesn't have power I tested it a few times and got nothing. I was going to pull the TIPM tomorrow and check pin 25 to see the connection to the C3 connector.
Feb 3, 2024 at 5:52 PM
Anything is possible. I think checking the connector pin is a good idea. When you do it, make sure there are no cracks or damage on the pin. It is a somewhat common issue.
Feb 3, 2024 at 6:14 PM
BOSSMAN19
  • 21 POSTS
Got ya! I'll let ya know what I find. It may not be until Monday until I get back to ya. I appreciate your help!
Ben
Feb 3, 2024 at 6:16 PM
BOSSMAN19
  • 21 POSTS
Good evening. So, I removed the TIPM and cleaned up the connectors along with the pin 25 and found it was a little on the dirty side. Now there was still no power at fuse 70 so I had opened up the TIPM to see if I could find the fuel pump relay and cannot find it. Before I order a refurbished one do you possibly know which one on the circuit board is the FPR? I have googled and nothing has popped up for a 2013 Ram 1500 with the 5.7. I took a picture of the PCB.
Feb 4, 2024 at 6:24 PM
You've been busy. I tried to find a layout of the PCB and there is nothing. Based on what you have already done, I feel funny suggesting this because likely you already have done it. However, check for cracks or burnt spots in the PCB. They can be hard to find, but use a magnifying glass to get an up-close look. You may be able to find it if there is one.
Feb 4, 2024 at 6:50 PM
BOSSMAN19
  • 21 POSTS
Good morning! Will do. I looked it over yesterday and didn't see anything out of the ordinary, but I will take a closer look for sure to see if I missed anything then get back to ya.
Feb 5, 2024 at 4:19 AM
BOSSMAN19
  • 21 POSTS
Hello!
One quick question or idea I have. What if I hook the PCB back up to the truck and turn the key on, if the relay is bad when I use the tester it shouldn't do anything, should it?
Feb 5, 2024 at 6:24 AM
That is correct. Please keep in mind there could be an issue related to the PCM providing a ground path to the primary side of the relay. That would be something other than a relay issue.
Feb 5, 2024 at 5:59 PM
BOSSMAN19
  • 21 POSTS
Got ya. I'll let you know what I find out. Once I get home from work tomorrow, I'll check it.
Feb 5, 2024 at 7:29 PM
BOSSMAN19
  • 21 POSTS
Okay, so, I got home and put the TIPM back together and reinstalled it in the truck. I turned the truck to run but didn't start it so that way I could check the fuses again. Low and behold fuse 70 has power and pin 25 is good. The truck started right up, no problem. Any thoughts?
Feb 6, 2024 at 2:30 PM
If I had to guess, the problem is the TIPM. Either there is an internal solder joint cracked or the connector itself is faulty. The best thing to do is put it back together and make short trips from home to see if there are any more problems. There is a chance a connector pin wasn't making good contact, and removing it and reinstalling it allowed it to make a better connection.
If it happens again, my first suspect is the TIPM.
Let me know if things change and thank you for the update.
Feb 6, 2024 at 9:01 PM
BOSSMAN19
  • 21 POSTS
I was thinking the same thing. Thank you for your help! I will keep you posted if things change.
Ben
Feb 7, 2024 at 3:59 AM
Ben,
No problem whatsoever. Hopefully, you simply created a better connection, and the problem is gone. LOL
Regardless, take care of yourself, and feel free to come back anytime in the future.
Feb 7, 2024 at 3:51 PM
BOSSMAN19
  • 21 POSTS
Will do!
Ben
Feb 8, 2024 at 4:21 AM
BOSSMAN19
  • 21 POSTS
I have the truck listed above that will stall out when I hit a bump. It will crank but not turn over. I had talked with someone on here before and thought I we had figured it out. Before I wasn't getting any codes. Now I am getting a P0688. I have blown 3 fuses to the fuel injectors. With my diagnostic scanner it will give me a wiring diagram to follow, but I'm a little stumped on what F342 is or K51. Any help will be appreciated. I'm about to lose my mind with this.
Mar 5, 2024 at 3:25 PM (Merged)
