Have this Ram truck 1500, code Z, auto transmission.
Ran beautiful for five years with regular maintenance and tires .Check engine light has never worked. Coming back from Florida pulling an enclosed car trailer the catalytic converter came apart and stopped up the exhaust. Limped it home okay, about ninety miles. Had new catalytic converter, muffler and intermediate pipe replaced, as well as the O2 sensor, wires burnt. NAPA unit. Muffler shop. The next year going over Black
Mountain, the transmission temperature light came on. Made it to Pigeon Forge OK, and back home to N.C.
Transmission acted funny and started to shift [banging] hard into overdrive. Had transmission replaced, [A518]? With a new torque catalytic converter. Had troubles shifting into overdrive and fourth gear. He had left the TV cable unhooked and burnt the overdrive clutches. Replace the clutches and still would not shift. Diagnosed as
the "transmission temperature switch", and replaced. NAPA unit. Transmission repair mechanic. Transmission worked fine but I noticed the engine idle was lower than it used to be. Truck started to run rough, so had a tune up of plugs, wires, cap and rotor button, and they wrung a screw off at the distributor cap. Replace the distributor, NAPA unit. Broke oil pressure switch while doing this. Replaced NAPA unit, and had a water leak at the timing cover. Had new steel timing gears and double roller chain and gaskets replaced. Truck would not stay running for a very long period of time, leave you on side of the road. Diagnosed as EGR and transducer. Both burnt out. NAPA units. Still would not keep running. IAC control, TPS, crank sensor, cam sensor for the new distributor ,and the ECM replaced. First repair shop, friend? Still cutting off. Second repair shop, where I used to work, replaced the coil and coil wire. Did not make it home.
Third repair shop the guy spent two weeks chasing wires and ohm-ed them back to the ECM, as well as replacing the crank sensor and the cam sensor, again, and said they were okay, before he had to quit to have back surgery.
I am at a loss.
Any suggestions as to a definite coarse to take without paying $130.00 per hour to diagnose or repair?
Ignition switch? Fuse panel under hood? Wiring harness? Wrong ECM? Gave numbers on original to match up. Reprogram ECM? at dealership? I have spent a lot of money to keep this truck and would hate to scrap it or sell it for peanuts.
Thanks
Does the check engine light have to work to store/read codes?
I am at a loss.
Thanks
Jun 6, 2018 at 11:18 AM
