Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Silverado
Engine
Mass Air Flow Sensor
Replace/Remove
truck only runs on starting fluid
2004 CHEVROLET SILVERADO
293,000 MILES
SHANE HOOD
MEMBER
1 POST
FOLLOW
I've changed my fuel pump, pcm, mass air flow sencor, crank shaft sensor, o2 sensor , and my truck still will not run. Please help
Mar 19, 2016 at 2:28 AM
CAR-MAN145
CERTIFIED EXPERT
You need three thing to start spark , fuel and compression which one are you missing?
Mar 19, 2016 at 7:07 AM
CERTIFIED EXPERT
Yes, does the ignition system work, are you getting spark, here are some guides for you to get started
http://www.2carpros.com/articles/how-to-test-an-ignition-system
also
http://www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator
and
http://www.2carpros.com/articles/how-to-test-engine-compression
Please let me know
Mar 22, 2016 at 6:29 PM
