Truck in limp mode
1999 DODGE DAKOTA
165,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
JOHN FEELEY
  • 6 POSTS
The truck is in limp mode for some reason and turns but will not fire. I replaced fuel pump,the pickup coil and the ignition coil. None of these things have worked and relays are all good.
Feb 17, 2018 at 7:24 AM
Good evening.
Does the engine not start?
you need fuel, spark and compression to run.
have you checked for spark and fuel pressure?
Feb 17, 2018 at 5:10 PM
JOHN FEELEY
  • 6 POSTS
It turns but will not fire. No spark or fuel though it is a new fuel pump.
Feb 17, 2018 at 7:37 PM
Okay, I sent two diagrams for you to view. check the fuses in each diagram for power on both sides with the key on.
Feb 18, 2018 at 4:56 AM
JOHN FEELEY
  • 6 POSTS
Okay checked all of the fuses and relays and still in limp mode so going to try replacing the crank position sensor today and hope that works. Any other ideas would be appreciated. Thank you for your time.
Feb 19, 2018 at 10:03 AM
It is possible but a way to check is to crank the engine and see if the tach moves up while cranking. that will tell you if a signal is getting to the pcm.
Feb 19, 2018 at 12:13 PM
JOHN FEELEY
  • 6 POSTS
Okay put in a new crank sensor and still no luck. No spark so any other ideas?
Feb 20, 2018 at 8:08 PM
Okay, can you check the voltage on the positive side of the ignition coil?
Feb 21, 2018 at 1:50 AM
JOHN FEELEY
  • 6 POSTS
I will try that today. Thanks
Feb 21, 2018 at 4:11 AM
Keep me updated.
Feb 21, 2018 at 4:12 AM
JOHN FEELEY
  • 6 POSTS
Took a few days break from this truck but now can say no voltage to ignition coil
Feb 23, 2018 at 8:11 PM
OK Can you test for voltage at the ASD relay with the key on?? This relay provides power to the coil and the fuel pump.
Feb 24, 2018 at 5:04 AM
