Truck hard to start?
1993 CHEVROLET 1500
115,000 MILES • 5.7L • V8 • 2WD • MANUAL
JON02
Truck is hard to start I’ve replaced
-Ignition coil
-Ignition control module
-Plugs
-Wires
-Distributor cap
-Rotor button
-Rebuilt the throttle body
-idle air sensor
-fuel pump and filter
-fuel pump relay
- oil pressure relay
Truck runs great just hard to start even when you turn it off it’s hard to start back but I can stall it out and make it die and it will fire straight back up as long as I don’t turn key off. When I turn the key on it’s like injectors are delayed in spraying, but I can cycle my key a few times and it will crank.
Aug 17, 2023 at 8:53 PM
Have you checked the fuel pressure regulator? Pressure could be too high or too low.
Here is a link that explains how to test fuel pressure and the regulator:
Also, if you haven't already, I recommend checking to see if there are diagnostic trouble codes stored. This has an OBD1 system, so you don't need a scan tool. All you need is a short jumper wire or even a paper clip. Follow the directions in this link and let me know if you find any codes:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
The idea that if you turn the key off and back on, it becomes hard to start makes me think it is losing line pressure. Do me a favor. Remove the vacuum hose from the fuel pressure regulator and see if there is any evidence of fuel in the hose.
Aug 17, 2023 at 9:50 PM
