Truck emits too much smoke
2000 CHEVROLET S-10
200,000 MILES • 2.2L • 4 CYL • RWD • MANUAL
EDGAR ARMENTA
  • 27 POSTS
the problem I having is that it spits out a lot of smoke through the exhaust. I changed the O2 sensors, the two of them and it still emits a lot of smoke out of the exhaust. black smoke to be specific, and it wastes more fuel than normal.
Nov 11, 2016 at 6:12 PM
SATURNTECH9
  • 30,869 POSTS
Have you checked for codes in the computer yet?
Nov 11, 2016 at 8:50 PM
SATURNTECH9
  • 30,869 POSTS
Also, have you checked the coolant temperature sensor yet?
EDGAR ARMENTA
  • 27 POSTS
Only code appearing is the p0171 indicating that the fuel system is too lean (Bank 1), the temperature goes up to 180, no higher. coolant temperature sensor does not appear on the list of codes either.
Nov 12, 2016 at 9:27 AM
SATURNTECH9
  • 30,869 POSTS
A bad coolant temperature sensor a lot times does not set a code .The code is most likely a vacuum leak somewhere.
Nov 12, 2016 at 12:01 PM
